Just got a wireless remote for the winch on my 2012 550. Anyone eve install one and any tips? Polaris 2500 lb winch
Ray. Before you start make sure they gave you the correct one. Part # should be
Part # 2877221. It will have somewhat instructions.
It is very simple to install. Took all of 5 minutes. Mine came with instructions but its really self explanatory once you look at the parts provided.
My Runva one came with a Y connector that plugged in in place of the handlebar control, then connect the handlebar control and wireless module to the Y. Done.
Just make sure the power { usually red } wire for the receiver is connected to a switched power wire otherwise it'll run your battery down if it's on all the time .
