1 - 8 of 8 Posts
Hey guys my first post, I have a 2018 sportsman 850 and plan to add a 75 watt light bar, 12inch with flood / spot. Not happy with stock lights. To keep it simple and still accomplish the task this is my plan. Disconnect both front bumper bulbs...do not think I need them with the light bar. Connect light bar positive at splice in one of the bumper bulb positive wires and ground the ground. Am I correct that light bar will light on low beam and I can switch to high beam...light bar off, pod light on? Any problem with light bar and I can plug in both bumper bulbs and disconnect light bar. This setup as I see lowers electrical load by unplugging front bulbs and seems very simple. Thanks in advance for your helpful comments.
better off taping the LED into the Pod high beam.When you come across someone on the trail you can switch on low beams
No you are incorrect the pod and low beams both stay on anymore its not one or the other. I always tap into my pod lights when putting light bar on and you get either low or low and light bar.
I missed the part where my 2018 is wired for all lights on for high beam, thanks 171000. Light bar would pull max 6 amps from what I see on line, so if I connect to pod for light bar power is there a chance of over load on electrical...what if I unplug the pod bulb? Lot of info on adding a relay from what I've read but is it necessary if I unplug pod bulb? Everyone have a safe holiday.
I have done 10-15 and never used relays there is a fuse and everything already in line from stock bulb. I even get fancy now and use a pigtail that plugs into where the bulb did and make a wiring harness off that. Unplug and can go right back to stock bulb
1 - 8 of 8 Posts
