Wiring VR help
2.4K views 11 replies 5 participants last post by  Off roader
So there is a yellow/ black wire and a yellow wire
coming from the stator and a yellow/red wire and a yellow wire from the VR.
Should the yellow/red go to the yellow/black wire?
#2 ·
What are we working on, a chainsaw?????
Make, Model, and year would help us help you!
#4 ·
No your not, I'm sure your fustrated. We like to help, but need to know what we are working on. Now lets get you an answer.
Your question has now been logged into the queue and the next available forum member will answer you shortly
#7 ·
Interesting.I guess I'll try it one way and if it doesent charge I'll swap them.
My being so cautious is because I just hooked a new one up and all of a sudden it looked like I had a fog machine in my garage. I had the red wire to power and the brown to ground. The VR melted big time, im so annoyed.
#8 ·
Depending on who wound the stator the charging side of the stator has a yel/red and a yellow wire going to the rec/reg and it make no difference which one is connected to which one, however if you connected the rec/reg red to the battery and brn to ground and it let the magic smoke out, then it won't work and needs to be replaced
