I have a 2004 sportsman 700. I cant get the alt. to charge or even try to charge the battery while the engine is running. Tested it at the battery, and all i get is battery voltage which isn't much because of an already weak battery. Also all of a sudden the 4wd indicator on the screen doesn't come on when you turn on the switch, But I haven't confirmed that the 4wd isn't actually working. Any idea or suggestions would be greatly appreciated. Is there a fuse that controls these circuts that could be bad maybe?
Welcome to the board! Is the battery any good?
no the battery is definatly bad. Does it have to have a good battery for the charging system to work? This bike has been sitting for a year and a half and was running just fine when put up, and I realise a battery tender should have been used, but I cant worry about that right now:eek:oops:
Try a good battery.That might be the problem.
try charging the battery n go from there......
Discussion Starter · #7 ·
okay once I put a stout charge on the battery it solved all my problems. I get 14.5 volts at idle, and all is well. Thanks alot guys:top:
