Wont Idle - Polaris Magnum 325 2001
1.7K views 33 replies 3 participants last post by  Lobsterdeli
She has never idled for me. Guy i got it from said it had something to do with the throttle cable and he has it zip tied to handle bars. It runs completely fine never bogs. It just acts like it completely gets starved of fuel. I have not adjusted the idle screw yet as i wanted to rule the throttle cable out.
#5 ·
THROTTLE CABLE / ELECTRONIC THROTTLE CONTROL (ETC SWITCH) ADJUSTMENT 1. Slide the boots off inline cable adjuster sleeve. Loosen adjuster locknut. 2. With handlebars centered and wheels pointing forward, turn adjuster sleeve until 1/16 - 1/8 freeplay is achieved at the thumb lever. Aftermaking any adjustment, “flip” the lever slightly to confirm adjustment. 3. Tighten locknut and slide boots over cable adjuster until they touch at the middle point of the adjuster. NOTE: Whenever throttle cable adjustments are made, always check oil pump adjustment and re-adjust if necessary. 4. Turn the handlebars from full left to full right with transmission in neutral. Engine RPM should not change and the engine should not die. If either of these occur, return to the first step.
#12 ·
The contacts are meant to touch when you have the throttle at idle and the lever moves the small distance. The carby settings are not right. Check the throttle slide & idle screw is just allowing the slide to open a little & the needle is set in the middle to start with. Top groove on needle is lean & the bottom one is rich
#24 ·
ATV ran fine from 1/4 throttle and above just would not idle before messing with it. Before tear down it would only start with choke and stay running with throttle. Then it would only run with choke. Found the idle screw to be missing. I think this is why the guy had the throttle cable ziptied to the handle bars to pull the cable. This in turn triggered the ETC by putting slack in the cable and the guy had to disable it by removing the contact and thats why I found it missing. The ETC has been set up correctly with 1/8" gap normally open. Becasue it ran fine before I will be just cleaning the entire carb and jets. This thing hasnt been riden in years so i think a good cleaning will be fine with original jetting. I will be replaing the idle screw so I should be able to acheive a good idle and remove this tom foolery. I will ultrasonic clean my carb, re-assemble and report back. @lateburd @leanardo2211 anything specific i should look out for when cleaning this carb or using it with my ultrasonic cleaner. TIA
#27 ·
Machine idled for its first time in its life. It kind blubbered and died with light throttle but screamed at 1/2- full throttle. idled a lil rough. could onlt get it to act normal if it was warmer. tried messing with the fuel screw but couldnt get it right. eventully it wouldnt start wiht my good settings. How do i go about adjusting this properly. I dont think i need to adjust the needle. are you turning the fuel screw a full turn at a time? also if its dying is that to much fuel or to less of fuel. Is clockwise or counterclockwise more or less fuel. My Bowl seal is shot so i took out the Mikuni and put in a chinese carb just cause i had one. Battery died trying to start it so gonna try and start with the chinese carb again today. should i be priming these carbs.
#29 ·
Remove anti-tamper plug and connect an accurate tachometer such as the PET 2100DX (P/N 8712100DX) or the PET 2500 (P/N 8712500). 2. Adjust idle speed using the idle speed screw to about 1600 RPM. 3. Turn the pilot screw (mixture screw) in or out slowly using the pilot screw wrench to obtain the highest idle RPM. 4. Re-adjust idle speed to specified RPM (1300 +100). 5. Again turn the pilot screw in or out slowly to obtain the highest idle RPM. 6. Turn the pilot screw out (counterclockwise) 1/8 to 1/4 turn. 7. Re-adjust idle speed to specified RPM (1300 +100).
How in the hell do you turn the screw while the engine is on I have to take the carb off everytime?!
#30 ·
This is not quite accurate - you warm the engine up thoroughly by riding for about 15 minutes - set the desired idle speed - adjust the fuel screw for the highest idle and then back the screw out in 1/8 turn increments pausing between changes for 5 to 10 seconds - when a drop of 50 rpm is observed, turn the screw out one full turn from the point the rpms dropped and it's done.
It takes a special tool - this is one I have and find the most useful
I do not have a bowl gasket on hand - it's part number 3130532 and it's $40 from Polaris - they are $30 on AMAZON
You can get one on EBAY for less than $9 with free shipping
#33 ·
You know........ sometimes I have to check myself to avoid confusion and based on the age of your machine the idle setting is not what I described.
For your model, you set the fuel screw at about 2 turns out from lightly seated and run the engine for about 15 minutes (not idling - ride it) then set a window fan in front of the ATV to move air across the engine simulating riding it - set the idle speed at the rpm you prefer and turn the fuel screw in until the rpm start to fall - from this point turn the fuel screw out and count the turns to the point the rpm starts to fall - now set the fuel screw half way between the two points that the rpm fell.
