1 - 2 of 2 Posts
I have a 2008 Sportsman Touring 800. Last winter it wouldn't shift into 4WD. Took it to Dealer who said it was bad front diff fluid and changed it. Worked fine after that. I use it to plow my driveway and recently I've been having the same problems. Anyone know what this could be? Also, anyone know of a place that performs factory authorized service in MN without the high prices?
try changing diff fluid again....but look at when you drain it...see if contaminated with water or metal bits...also check wire connectors on diff...clean them an add di electric grease....most places authorized to service have a high labor rate....you can look for a shop that does like snowmobiles..ATV ..Bikes....just have them change the oil to start with...and see if that work..if not then its tracing the problem ....start simple an work up...loll...but check connectors also....
1 - 2 of 2 Posts
