Yes, I did put it in part and went through all gears, tried N and P. Set hand brake. NothingSet the brake or parking brake?
I also threw the battery tender on it. But I also don't ride it in the mud or deep water. It has historically always starred like a charm and it's not even a year old.Yes, I did put it in part and went through all gears, tried N and P. Set hand brake. Nothing
Sent from my SM-A715W using Tapatalk
I'll have to check the brake switch and look it up. No idea where that isChecked all fuses/relays, off/run switch, brake switch....etc...?
The brake switch is at the brake lever on handle bar, do your brake lights come on when the lever is squeezed?I'll have to check the brake switch and look it up. No idea where that is
YesThe brake switch is at the brake lever on handle bar, do your brake lights come on when the lever is squeezed?
