1 - 8 of 8 Posts
SO YESTERDAY i unhooked the oil line and premied my gas and went to fire it Up and it wouldnt fire up well after awhile i assumed it is getting flooded idk why it is though i know it has plenty of spark and compression and seems to be getting plenty of gas as well oh yeah i even plugged the oil injection line,man is this ever so depressing! hopefully u will know what to do, so i just came in from messing with my atv and still nothing i even went as far as taking out the drain plug for the crankcase a little bit of fuel came out but not a whole bunch, and hooked it all a back up tried to fire it up and still nothing so i removed it again and this time i took off the carb and spark plug turn the engine over about 30 seconds or so with the starter. hooked back up and still nothing this time around i even blasted some compressed air into the carb boot the spark plug hole and the crankcase plug hole so im stumped any advice would be great at this time oh and i even checked to see if i was getting spark and i am . and i left everything unhooked and off to see if maybe it will dry out if it is because its flooded and i put new plug in it
THANKS IN ADVANCE
RUBEN
Ok Ruben. You have a 95 scrambler 400 4x4. is it 2 stroke or 4 stroke? My guess is 2 stroke?! Dosen't really matter the basic checks are the same. Remember this every time you attempt a diag. on a no start condition of a gasoline engine. The check is in this order. Spark, Fuel, and then Compression.
First some questions.
1. How long has it been sitting since last start up?
2. Did it run ok at that time?
3. Do you have the same fuel in the tank from last start up?
4. I know you have turned on the key but did you check the shut down (kill) switch and make sure it is in the run position? (it is very common to forget it is there.)
5. Do you have a choke on this engine?
Discussion Starter · #4 ·
after reading a few posts yesterday i got to thinking and i didnt have the plug in the right place i had plugged the oil feed line not the oil line to the engine. but i plugged that up today but still no dice so i went to ahead and checked the carb. and guess what one of the floats was sticking well i fixed it threw it back on but still nothing idk what it is but when i put the choke on full it back fires and a puff of smoke comes up and through. but i went ahead and took apart the carb and have it soaking over night.
thanks for any feedback
RUBEN
Forward Message
so i just put together my carb today and threw it on and still nothing idk what it could be i even disconnected the black cable from the cdi to make sure that the key or the lh switch isnt preventing it from firing up is there anyway to eliminate the e.t.c. and another ? would the reed valve be causing this somehow
THANKS
RUBEN
Discussion Starter · #6 ·
well guys and gals i think i found the culprit , well my host dad came over last night and after explaining to him what my atv was doing he tells me that it sounds to him like it is timing issues,well i explained to him that it cant be because i put the stator on myself so that it couldnt be well today i went to work on it and i said what the hell let me check , so i take off the recoil starter and low and behold my flywheel is as loose as can be so i take the flywheel nut off and wouldnt u know it that 1 my wood ruff key is completely sheered of and 2 my flywheel is basically junk now because the slot where the key goes into has completely expanded so the key will not catch now and all of my problems started with a faulty solenoid which turned into the slotted nut coming loose, which that in turn turned into needing a new starter and benndix, which turned into needing a new throttle cable, and finally now neeeding new flywheel. gosh i hope that this is it.
THANKS
RUBEN
P.S. i dont know about u guys and gals but i hate it when people post their problems on here and then never post the solutions,
glad you got it fixed. I agree, I always try to post an outcome.
Discussion Starter · #8 ·
success i got it running im so happy YES i threw the flywheel on and gave it a crank and it fired right up now the only problem i might have isi wish there was a way to know if the oil injection was working. with me messing with the oil injection, first had to replace the throttle cable then i had to put the check valve back on the oil to the carb boot line idk i wish there was a way for the atv itself to shut down if it wasnt getting oil cause ill tell u one thing the last thing i need is for the piston to seize on me
RUBEN
1 - 8 of 8 Posts
