No there 12" rims. 12" rims won't clear the brake caliper.
They look sharp and it seems to be a reasonable price.... However, bp405 is correct. Your 2016 Scrambler 850 has 14" rims to clear larger brakes/calipers, so those 12" rims will not work on your machine (in it's stock form).
Look for the same setup in a 14" rim and you'll be golden!
you can make them fit if you are willing to shave your calipers a bit but you can forget them otherwise as they don't make them in 14". if you're interested in getting a beadlock wheel, i recommend you check out the STI HD5s. they come in a 5+2 offset which is as close to stock offset that you'll likely find in a true beadlock as most are 4+3 offset.
You can get the bighorn tires in the correct size, but you will have to find other rims.
Do you need beadlocks?
