1 - 1 of 1 Posts
Nice bike. Looking to trade or sell so I can get a Sportsman 700/800 EFI. Have cash to add on top though. Bike completely gone through 10 hours ago. Fresh motor & clutch. Chain/sprockets. Battery. All bearings, etc. Bike is strong. Properly broken in. Always used Honda oil and filters only.
*Stock bore Wiseco piston with 11:1 compression ratio so its pump gas safe
*HMF Full exhaust
*Air box lid removed and drilled & a BMC Filter
*Hot cams Stage 2 cam
*Hardened Rockers
*Upgraded springs
*Exteme Port N' Polish
*Valve job with seals
*Spal 4" puller fan mounted on the oil cooler on a switch to keep it cool. It is much better than any larger cooler/tank combination.
*CRF450 Timing chain, OEM Tensioner, and both guides.
*Keihn 42mm carb off of the 04/05 450r.
*Valves just adjusted again after break in period and set to .004" Intake & .005" exhaust
*Henson Clutch
*Motion Pro clutch cable
*ARC clutch and front brake levers.
*Pro Taper Conquer bars
*Clip on kill switch
*Brand new Ceramic pads front and rear
*Steel braided brake lines
*ARC rear brake lever
*Lonestar Racing parking brake block off
*New all balls bearing kit installed.
Suspension/Body/Frame/Tires/Wheels:
*Elka Triple Rate front shocks with external reservoirs. Valved for 185lb rider.
*Custom Axis rear shock with external reservoir mounted on right side of the frame. Also valved for 185lb rider.
*Houser +2 A-Arms up front
*04/05 450r swingarm
*G Force Extended Axle and G Force Extended Hubs for a total of +4. The bike is about 48" wide all around and corners like a dream. Never have I had an issue with this bike tipping over in corners.
*Janssen Steering Stabilizer
*Grey Maier Race Cut plastics
*One Industries Seat. Has a few tiny rips but they haven't spread in 2 years.
*Spastic graphics kit
*AC Racing front bumper
*Pro Armor Nerf Bars with solid heel guards
*AC Racing wide foot pegs
*Gusseted frame & subframe
*Maxxis RZR tires up front and Carlisle Turf Tamers in the rear. The Turf Tamers hook up exceptionally well in the hole shot on most surfaces.
*Bead lock front wheels & black ITP solid rear wheels.
Sent from my iPhone using Tapatalk - now Free
1 - 1 of 1 Posts
