That is for an oil injection hose - the barb is part #3 - the hose goes to a barbed nipple on the LH side of the carb (there are no clear pics of the carb that exhibit the oil line nipple location)
No idea on that one. There are a couple youtube videos floating around that show how to add a Diode into the wiring harness to bypass the reverse overide button. Perhaps that is what that is????. I would follow the wiring diagram latebird posted. Who knows what the PO did there.
Where did you get this diagram? Partzilla and Cheap cycle parts don't have this one. I can't find the vent tube you pointed out. I have Polaris xlporer A99CC28CA.
The reverse limiter switch allows you to use full throttle in reverse gear. From the factory, the yellow button on the left switch block is the limiter. The machine has a speed limiting switch that kicks in when you shift into reverse. It only allows the machine to creep at very low speed in reverse. By pushing the yellow button it overides the speed limiting switch and allows full throttle to be used. This is often the wiring that guys butcher up on these things trying to eliminate the need to use the button. Only way to correct what some hack has done to the wiring is follow the wiring diagram closely and try to figure out what they changed. Tedious work, but only way to fix it properly.
Wiring on the 96 Xplorer 300 was pretty basic
red with a white stripe is switched power (hot when the key is on)
white with a red stripe is the control power wire from the starter switch to the solenoid
brown is ground
black is ignition kill
In your last post - there is no device in the wiring diagram with 2 red/wht wires going to it - I have no idea what it is or where it goes - might be year model specific
The wiring diagram tells me that the wire cluster from the crank case is for the stater and the white wire is ground. This has been spliced with the thick red wire by wire nut coming from the front.
So I found thick black oil hose still attached but cut off to the nipple at the location in red. The hose that goes on the #3 nipple then to side of Carb, I have a hose already there which appears to be a bypass by the pic I provided. If I put the correct hose in those locations where would the hose at the top of the intake go to, and the black cut off hose go to?
So sorry, I forgot to attach the pics. First pic is oil pump where in red I found a thick black oil hose had been cut off at the nipple. Where does it go? Second pic is the carb where a single hose is attached from the top of the intake to the left side where the small oil pump hose ( from #3 nipple) is supposed to attach. Where is the hose originally supposed to go?
OH BOYEE - the epitome of ignorance of the previous owner..............
In the first pic, that nipple is for the supply hose from the oil tank to the oil pump - #17 connects to the nipple in the red circle
In the second pic, the dumb bass connected the one of the carb float bowl vents to the oil injection nipple - left unplugged it would run lean and the idle would be high - connected as it is it is sucking fuel vapor from the float bowl it will run rich and the idle speed would be difficult to set. The idle mixture would be impossible to set so it would not idle long before loading up and dying from being flooded.
Since the oil pump has been disconnected, run dry and possibly full of dirt, it will need to be tested before reconnecting.
21 - 37 of 37 Posts
