Greetings Gurus!
I recently bought a non-running Polaris Xplorer 300. Previous owner said he had been successfully running it without a battery(?) I was intrigued. Anyway, apparently he had been using the recoil pull to start it. However, now it was not starting. My shoulder isn't what it used to be, so at some point I need to re-instate the electric start feature. That will include re-adding / wiring a starter solenoid, etc. So far, I've thoroughly cleaned the carb and replaced the fuel filter. A few pulls (argh) no start. Next I'll pull the plug and likely replace it. Pull, pull, argh. I'll feel more confident if I can get it to start. Then continue on to get the electric starter going. My shoulder will thank me. Thank you all for access to your expertise!
