1 - 2 of 2 Posts
2 stroke xpress 300 carb. Aluminum built worse than anything I’ve ever seen before and while the needle might still function, thinking of just cleaning it up and parting it. Been looking all over, but finding the two stroke carb has been an issue. Wondering if any info on it could help, or if any aftermarket carbs will do just as well.
It's a Mikuni - carbs are just mixers - doesn't make any difference who made it, if it works right - all you have to do is find one that is the same size and mounts the same way - calibrate for the engine installed on and the job is done.
1 - 2 of 2 Posts
