righto guys
Bike is 06 sportsman 450
Its running rough, can pick up a miss when reving up in netural and doesnt rev right out, when i have the throttle depressed fully in netural you can hear it missing and small back fires
When going down the road it will splutter and fart about, come right for 5 sec then die back down
I have put new plug in, flushed the fuel with fresh, drained the carb, then pulled carb off, gave it a clean down and re assembled
The new plug is Black when removed, i can smell gas out the exhaust when i go to idle when its missing
When its idling or under slight revs ans missing if i pull the choke cable it doesnt effect it until the the choke is 3/4 out
Suggestions please
thanks for your help
Suggestions please
