0 ohms on front diff
6.3K views 12 replies 4 participants last post by  polman500
i have a 2021 RZR XP TURBO S it is mostly used for running around town, its only been put into AWD 4 times for a total of an hour, wires everything look brand new, light on switch comes on when activated, icon in speedo does not come on, trop code 520207 3 and ohms at diff show 0 any thoughts of what to do would be appreciated nearest dealer is a long way from me.
#2 ·
to the forum
Your question has now been logged into the queue and the next available forum member will answer you shortly
#3 · (Edited)
#4 · (Edited)
All Wheel Drive Control Circuit
Voltage Above Normal, Or Shorted To High Source5202073
#5 ·
Di you double verify the readings with another tester???
#7 ·
Sounds correct to me, if its showing zero ohms its shorted as the code is indicating...
#8 ·
Ok thats a tough one then. You'd have to replace the coil inside the diff as it sounds like the wires or coil itself are fried/broken. If you put 12vdc to the diff do you hear and noise??? What if you ohm the wires to the case any reading???
