2000 Scrambler 400 4x4
2.5K views 3 replies 4 participants last post by  Bruce!
I recently purchased 400 Scrambler 4x4. It had an aftermarket exhaust silencer on it. Way to loud. I do believe the rest of exhaust is stock. I found a used stock exhaust complete. I removed aftermarket exhaust silencer and put the new stock silencer on my quad. I started it up and it was alot more quiet. took it for a test ride and the stock silencer started to glow red with heat. It also started to eject tiny sparks out of exhaust silencer. any ideas?
#2 ·
Most stock exhaust glows from the heat, thus the reason they surface rust so fast. As far as the sparks, there is a good chance that there was just loose particles inside that are burning there way out. Ride it a couple times and see if it blows out and stops.
#3 ·
Depending on the year, some have a plug in the bottom you can remove to clean it out. Remove the bolt and with the machine cold or the use of a rag when hot, cover the tail pipe, rev the engine and watch for debris to come out of the hole.
