2007 Polaris sportsman 800 doesn’t run right need help!
4.1K views 11 replies 4 participants last post by  polman500
I have a 2007 Polaris sportsman 800 that just seems to be getting choked like it’s really not letting all it’s power go and it won’t idle it cranks up and drives ok; fast but not crazy fast if kinda lunges and seems to bog out and it will idle for a minute when you stop but then shuts off and my speedo is broke so I can’t see rpms or even run to see codes I need help!
#2 ·
Kinda of need that display to read the codes. At this point it's a crap shoot.
#4 ·
Checked ETC?
Fuel filter?
fuel pressure?
Plugs/wires/boots?
Intake tight?
TBAP and TPS harnesses good?
TPS good and calibrated?
Air filter and box in good shape?
Throttle body clean?
Oil pressure?
Compression?
You say the speedo is "broken"...is it actually broken or just don't work? If it just don't work, have you checked the wiring to it?
#8 ·
ETC= electronic throttle control in the throttle lever box there is a set of points that must have a gap. You adjust the throttle cable about 10" down from the box so you've got about 1/8" slack. its a safety feature to cut ignition in case of broken throttle cable.
fuel filter up under front on frame between the struts. Its a big metal canister just like on your pickup and you can get a replacement at auto parts store.
Fuel pressure is checked at the fuel rail Schrader valve and should be around 40 psi. Pump is in the tank like your pickup and replacement can be gotten at the auto store...common issue.
Plugs/wires/boots are self explanatory.
Air intake, filter, box, throttle body connections must all be tight and sealed or it won't run good at all.
Likewise, if the throttle body gets dirty/gunked up it will run bad.
TBAP=temp/ barometric air pressure sensor on the intake in front of the air box.
TPS=throttle position sensor on the side of the throttle body just like your automobile works sorta like a rheostat increases voltage with throttle valve opening and tells computer amount and duration of injector spray. It must increase voltage smoothly throughout its range of movement without any jumps or dead spots. Must be calibrated/set along with throttle stop/idle screw for correct idle speed and function.
Oil pressure ...since that engine has hydraulic lifters if the regulator dowel sticks from wear/lack of maintenance low oil pressure can affect performance/running.
Low compression and oil consumption causes a whole other set of problems...carbon-caked valves etc. that just compound each other also causing poor performance.
You just have to start checking and eliminating things till you narrow it down. Use the search function of the forum and do a lot of reading. Any problem you could possibly have has been discussed on here at one time or another.
Oh yeah...you should be able to find a good used speedo on ebay pretty reasonable...you REALLY need one.
A service manual is also indespensible.
#5 ·
The speedo got water damaged I took it apart and there are some damage on the mother board and what’s all the abbreviations stand for sorry I’m new to this last four wheeler was a 2004 Honda foreman 450 lol didn’t have none of this fancy stuff
#6 ·
The etc I have looked into already tomorrow I had planned on pulling the spark plugs and as of right now I got a full tank of high octane gas with some sea foam but it’s hard to run it through when it doesn’t idle
#7 ·
Check and or replace all the free / cheap stuff.
Start with cleaning the air filter and making sure the air box isn’t damaged and you don’t have any sort of nest in there.
From there I’d check the fuel filter and plug wires.
#11 ·
