I have a 1997 / 1996 model 425 Magnum (Norwegian model).
It (the engine) has suddenly started to run quite bad. It starts perfect, on idle it runs so nice, but when I give more trottle then it starts running really bad. To me it seems like there are either something wrong with the carburator or the ignition. It is not possible to get it up on high rpm.
I have tried to disconnect the black cable into the speed limiter, but that had no effect.
The carburator has been checked and should be in perfect condition.
The intake have been checked and are without any cracks etc.
New spark plug and cable installed.
Airfilter cleaned.
Valve clearance have been checked and seems to be OK.
Fuel pump seems to work OK - it pumps quite a bit of fuel..
I would be so glad for some good advices!!!:thinkerg:
Airfilter cleaned.
