Need wiring diagram
8.1K views 5 replies 2 participants last post by  LATEBURD HERE 2 HELP
I'm not sure what year but it's a 90s Polaris 6x6 with the 425cc magnum, it's not in good shape and I'm trying to begin rewiring it, I've got all the wires coming from the engine near the pull start intact and I've got the solenoid in decent condition with a battery wire, starter wire and what I believe would be the hot wire the the rest of the atv. The rpm limiter and the box below it are all disconnected but the coil is still connected and the spark plug wire is there, what colors go where? The ignition and lights are all gone, I gotta make my own...
#2 ·
Here ya go - a 90's model wiring diagram - since you don't know what model or year it is, I just copied the first one I ran across - I'm pretty sure they are all the same anyway, so it shouldn't make any difference.
Some things that are consistent; Red is hot, red/blk is switched hot, red/blk connects to red/wht through the LH hand kill switch, red/wht is the 12v feed to the lights and such, wht/red is the control voltage wire to the solenoid, brn is ground and blk is the ignition kill wire (connect blk to ground to kill the spark)
If you decide you would like the correct wiring diagram (if this is not the one), just find the model number on the frame and relay it to me.
138346
