New to me 2014 570, few questions
2K views 6 replies 3 participants last post by  indyred570
Hi all,
I just picked up a 2014 570 with 600 miles on it. It looks we'll maintained and since all the add ons (front and rear bumpers, winch, led bar and heated grips) are all Polaris, I'm guessing the work was done by a dealer.
Here are my questions; what kind of drain do the heated grips place on the battery? Safe to have on most of the time?
I have a battery tender with a plug I can wire to battery, but with it's placement, is there somewhere else?
Lastly, this breather or drain plug struck me as in an odd location, is it correct (right rear wheel well)? See picture
As always I appreciate all of your help.
#2 ·
That line in your pic goes to the foot brake master cylinder, it's suppose to have brake fluid in it. Follow that line up to the opposite side of the quad & you'll find the fluid reservoir.
For the battery tender hook up, pull the plastic piece under the headlight pod and you'll see a small distribution block with positive & negative from the battery, you can connect to those posts if you want.
Reactions: sportsmandan
#3 ·
Turns out the nipple the hose would slide over is broke. Is this a part that can be purchased stand alone? I didn't see it on the rear brake pedal diagram.
Is the bike ok to use without it for now? Was planning a ride for Sunday.
Hooked up the tender connector where you pointed me towards, works great, and hides away nice in compartment when not in use.
#6 ·
Having the VIN and build date would be helpful - but, there were 3 master cylinders available - the models listed with 2 different MC's were all EFI models. The carbureted model used part 1911551. The EFI models used either 1911688 (built on or before 8-12-13) or 1912301 (built on 8-13-13 and later) - both had 1/2" bore and clevis attachment, but 1912301 is listed as 520mm length
#7 ·
If you're lucky you might still find a sticker on the rear torsion bar that has the VIN number & build date, that way you know for sure.
