newbie here
5.6K views 7 replies 3 participants last post by  Jerime123
I'm thinking of buying a 2000 model 325 magnum 2x4. Price is reasonable. Problem is the rear end was replaced with a 2001 rear axle and the rear wheels don't fit. My question being will the original hubs from the blowen axle fit on the new axle or am I looking at having to purchase new rear wheels? Any help will be appreciated. Thank you.
#2 ·
Welcome, I recommend you go to a website that sells OEM parts. Look up the machines on their site and cross reference the part numbers. Not just the hubs but take a look at the supporting parts as well. If you still have any doubts just come back and we'll try to help you further. Unless someone here has made this swap before you may be waiting and not get any response. If you have the hubs then just do a comparison and measure your tolerances. Again compare things like bearing and axle part numbers to see if they are the same. Manufacturers will always attempt to build with what they already own before going to new parts. Some will adjust the length of the axle but keep the bearings, seals, and hubs for instance.
#4 ·
I've looked all over for hubs. They are the same from 99 to 2001. This smaller bolt pattern. Did Polaris change hub design mid year? I'm seriously confused here lol. I naught this quad for $300. So I'm not to upset if I need to purchase a new set of wheels for it. Can the old rear wheels be machined to fit? I have a friend who owns a machine shop.
#5 · (Edited)
This Polaris 5131777 HUB,R.WHEEL,LG.FLANGE(MACH) is used in the following models and assemblies:
1998 SCRAMBER 500 (W98BC50A) - Rear Wheel
1998 SCRAMBLER 400 (W98BC38C) - Rear Wheel Scrambler 400
1999 MAGNUM 500 (A99CD50AA) - Rear Wheel Drive
1999 TRAIL BLAZER 250 (A99BA25CA) - Rear Wheel
2000 325 MAGNUM 2X4 HDS (A00CB32FA) - Rear Wheel Drive - A00cb32aa
2000 325 MAGNUM 4X4 HDS (A00CD32FA) - Rear Wheel Drive - A00cd32aa
2000 325 MAGNUM 4X4 HDS II (A00CD32FB) - Rear Wheel Drive - A00cd32aa
2000 500 MAGNUM 4X4, HDS (A00CD50FA) - Rear Wheel Drive - A00cd50aa
2000 500 MAGNUM 4X4, HDS II (A00CD50FB) - Rear Wheel Drive - A00cd50aa
2000 INT'L BIG BOSS (A00CL50DA) - Rear & Middle Wheel - A00cl50aa
2000 MAGNUM 325 2X4 (A00CB32AA) - Rear Wheel Drive
2000 MAGNUM 325 2X4 (A00CB32CA) - Rear Wheel Drive - A00cb32aa
2000 MAGNUM 325 4X4 (A00CD32AA) - Rear Wheel Drive
2000 MAGNUM 325 4X4 (A00CD32CA) - Rear Wheel Drive - A00cd32aa
2000 MAGNUM 500 (A00CD50AA) - Rear Wheel Drive
2000 MAGNUM 500 EB (A00CD50AB) - Rear Wheel Drive - A00cd50aa
2000 SPORTSMAN 6X6 (A00CL50AA) - Rear & Middle Wheel
2000 TRAIL BLAZER (A00BA25CA) - Rear Wheel
2000 TRAIL BOSS (A00AA32AA) - Rear Wheel
2000 TRAIL BOSS (A00AA32AB) - Rear Wheel
2000 TRAIL BOSS (A00AA32CA) - Rear Wheel - A00aa32aa
2000 XPEDITION 325 (A00CK32AA) - Rear Wheel Drive
2000 XPEDITION 325 (A00CK32AB) - Rear Wheel Drive - A00ck32aa
2000 XPEDITION 425 (A00CK42AA) - Rear Wheel Drive
2000 XPEDITION 425 (A00CK42AB) - Rear Wheel Drive - A00ck42aa
2001 325 MAGNUM 2X4 HDS (A01CB32FC) - Rear Wheel Drive - A01cb32aa
2001 325 MAGNUM 4X4 HDS (A01CD32FB) - Rear Wheel Drive - A01cd32aa
2001 500 MAGNUM 500 HDS (A01CD50FB) - Rear Wheel Drive - A01cd50aa
2001 INT'L BIG BOSS 6X6 (A01CL50DA) - Rear & Middle Wheel - A01cl50aa
2001 MAGNUM 325 2X4 (A01CB32AA) - Rear Wheel Drive
2001 MAGNUM 325 2X4 (A01CB32AB) - Rear Wheel Drive - A01cb32aa
2001 MAGNUM 325 4X4 (A01CD32AA) - Rear Wheel Drive
2001 MAGNUM 325 4X4 MOSE (A01CD32AB) - Rear Wheel Drive - A01cd32aa
2001 MAGNUM 500 (A01CD50AA) - Rear Wheel Drive
2001 SPORTSMAN 6X6 (A01CL50AA) - Rear & Middle Wheel
2001 TRAIL BLAZER (A01BA25CA) - Rear Wheel
2001 TRAIL BLAZER (A01BA25CB) - Rear Wheel - A01ba25ca
2001 TRAIL BOSS (A01AA32AA) - Rear Wheel
2001 TRAIL BOSS (A01AA32AB) - Rear Wheel - A01aa32aa
2001 TRAIL BOSS 325 SE (A01AA32AC) - Rear Wheel - A01aa32aa
2001 XPEDITION 325 (A01CK32AA) - Rear Wheel Drive
2001 XPEDITION 425 (A01CK42AA) - Rear Wheel Drive
2001 XPEDITION 425 (A01CK42AB) - Rear Wheel Drive - A01ck42aa
2001 XPEDITION 425 (A01CK42CA) - Rear Wheel Drive - A01ck42aa
2002 INT'L BIG BOSS 6X6 (A02CL50DA) - Rear & Middle Wheel - A02cl50aa/Da
2002 LUH 6X6 PPS (C02CL50AB) - Rear & Middle Wheel
2002 SPORTSMAN 6X6 (A02CL50AA) - Rear & Middle Wheel /Da
2002 TRAIL BLAZER (A02BA25CA/CD) - Rear Wheel - A02ba25ca/Cb/Cd
2002 TRAIL BLAZER FREEDOM (A02BA25CB) - Rear Wheel - A02ba25ca/Cb/Cd
2002 TRAIL BOSS (A02CA32AA/AB) - Rear Wheel
2002 XPLORER 4X4 (A02CG25CA) - Wheel (Rear)
2003 SPORTSMAN 6X6 (A03CL50AA) - Rear & Middle Wheel
2003 TRAIL BLAZER 250 (A03BA25CA/CB) - Rear Wheel
2003 TRAIL BOSS 330 (A03CA32AA) - Rear Wheel
2004 A04BA25CA TRAIL BLAZER (A04BA25CA/CB) - Rear Wheel
2004 A04CA32AA TRAIL BOSS 330 (A04CA32AA/AB/FA) - Rear Wheel
2004 SPORTSMAN 6X6 (A04CL50AA) - Rear & Middle Wheel
2005 SCRAMBLER 500 4X4 (A05BG50AA) - Rear Wheel /Fa
2005 SPORTSMAN 6X6 (A05CL50AA) - Rear & Middle Wheel
2005 TRAIL BLAZER (A05BA25CA) - Rear Wheel /Cb
2005 TRAIL BOSS 330 (A05CA32AA) - Rear Wheel /Ab/Ac/Fa
2005 TRAIL BOSS 330 QUADRICYCLE (A05CA32EA) - Wheel, Rear
2006 SCRAMBLER 500 4X4 (A06BG50AA) - Wheel, Rear /Fa
2006 SPORTSMAN 6X6 (A06CL50AA) - Wheel, Rear & Middle
2006 TRAIL BLAZER (A06BA25CA) - Wheel, Rear
2006 TRAIL BOSS 330 (A06CA32AA) - Wheel, Rear /Ab
2007 SCRAMBLER 500 2X4 INTL (A07BA50FA) - Wheel, Rear
2007 SCRAMBLER 500 4X4 (A07BG50AA/FA) - Wheel, Rear
2007 SPORTSMAN 6X6 (A07CL50AA) - Wheel, Rear & Middle
2007 TRAIL BOSS 330 (A07CA32AA) - Wheel, Rear
2008 SCRAMBLER 2X4 INTL (A08BA50FA) - Wheels, Rear
2008 SCRAMBLER 500 4X4 (A08BG50AA) - Wheel, Rear
2008 SCRAMBLER 500 4X4 INTL (A08BG50FA) - Wheel, Rear
2008 SPORTSMAN 6X6 (A08CL50AA) - Wheels, Rear & Middle
2008 TRAIL BLAZER 330 (A08BA32AA) - Wheels, Rear
2008 TRAIL BOSS 330 (A08CA32AA) - Wheels, Rear
2009 SCRAMBLER 2X4 INTL (A09BA50FA) - Wheels, Rear
2009 SCRAMBLER 500 4X4 (A09BG50AA) - Wheel, Rear
2009 SCRAMBLER 500 4X4 INTL (A09BG50FA) - Wheel, Rear
2009 TRAIL BLAZER 330 (A09BA32AA) - Wheels, Rear
2009 TRAIL BOSS 330 (A09CA32AA) - Wheels, Rear
2010 SCRAMBLER 500 4X4 (A10NG50AA) - Wheels, Rear
2010 SCRAMBLER 500 4X4 INTL (A10NG50FA) - Wheels, Rear
2010 TRAIL BLAZER 330 (A10NA32AA) - Wheels, Rear
2010 TRAIL BLAZER 330 INTL (A10NA32FA) - Wheels, Rear
2010 TRAIL BOSS 330 (A10EA32AA) - Wheels, Rear
2010 TRAIL BOSS 330 INTL (A10EA32FA) - Wheels, Rear
2011 SCRAMBLER 500 4X4 (A11NG50AA) - Wheels, Rear
2011 SCRAMBLER 500 4X4 INTL (A11NG50FA) - Wheels, Rear
2011 TRAIL BLAZER 330 (A11NA32AA) - Wheels, Rear
2011 TRAIL BLAZER 330 INTL (A11NA32FA) - Wheels, Rear
2011 TRAIL BOSS 330 (A11EA32AA) - Wheels, Rear
2011 TRAIL BOSS 330 INTL (A11EA32FA) - Wheels, Rear
2012 SCRAMBLER 500 4X4 (A12NG50AA) - Wheels, Rear
2012 SCRAMBLER 500 4X4 INTL (A12NG50FA) - Wheels, Rear
2012 TRAIL BLAZER 330 (A12NA32AA) - Wheels, Rear
2012 TRAIL BLAZER 330 INTL (A12NA32FA) - Wheels, Rear
2012 TRAIL BOSS 330 (A12EA32AA) - Wheels, Rear
2012 TRAIL BOSS 330 INTL (A12EA32FA) - Wheels, Rear
2013 TRAIL BLAZER 330 (A13NA32AA) - Wheels, Rear
2013 TRAIL BLAZER 330 INTL (A13NA32FA) - Wheels, Rear
2013 TRAIL BOSS 330 (A13EA32AA) - Wheels, Rear
2013 TRAIL BOSS 330 INTL (A13EA32FA) - Wheels, Rear
SERIES 10 PTV 6X6 (C10CL50AA) - Rear & Middle Wheel
What makes you believe the hubs you got are stock? This took me less than 3 minutes to find. You can do the same for the rims or anything on your machine. If the hubs will fit then I would give them a try. Could be that the replacement axle had aftermarket or swapped hubs already. When you compare the different models within the two years in question it looks like they may have put the wider spread hubs on the 4x4 or vise versa. But the axle is the same right? Or it wouldn't have fit. I do not mean to sound curt here, it's that with buying your machine or any ATV I believe it's vital that you learn and teach yourself as much about your machine as you can if you intend to ride into the back country. You can machine anything to work, but what happens when you have to fix the part next to it?
I didn't check any of the numbers set in parenthesis so if you paste them into Google with the word Polaris you'll get lots to look at for comparison. Hope this helps to get you started. happy trails.
#6 ·
This Polaris 5131862 AXLE,REAR is used in the following models and assemblies:
1999 MAGNUM 500 (A99CD50AA) - Swing Arm/Rear Gearcase Mounting
2000 325 MAGNUM 2X4 HDS (A00CB32FA) - Swing Arm/Rear Gearcase Mounting - A00cb32aa
2000 325 MAGNUM 4X4 HDS (A00CD32FA) - Swing Arm/Rear Gearcase Mounting - A00cd32aa
2000 325 MAGNUM 4X4 HDS II (A00CD32FB) - Swing Arm/Rear Gearcase Mounting - A00cd32aa
2000 500 MAGNUM 4X4, HDS (A00CD50FA) - Swing Arm/Rear Gearcase Mounting - A00cd50fb
2000 500 MAGNUM 4X4, HDS II (A00CD50FB) - Swing Arm/Rear Gearcase Mounting
2000 MAGNUM 325 2X4 (A00CB32AA) - Swing Arm/Rear Gearcase Mounting
2000 MAGNUM 325 2X4 (A00CB32CA) - Swing Arm/Rear Gearcase Mounting - A00cb32aa
2000 MAGNUM 325 4X4 (A00CD32AA) - Swing Arm/Rear Gearcase Mounting
2000 MAGNUM 325 4X4 (A00CD32CA) - Swing Arm/Rear Gearcase Mounting - A00cd32aa
2000 MAGNUM 500 (A00CD50AA) - Swing Arm/Rear Gearcase Mounting - A00cd50fb
2000 MAGNUM 500 EB (A00CD50AB) - Swing Arm/Rear Gearcase Mounting - A00cd50fb
2000 XPEDITION 325 (A00CK32AA) - Swing Arm/Rear Gearcase Mounting
2000 XPEDITION 325 (A00CK32AB) - Swing Arm/Rear Gearcase Mounting - A00ck32aa
2000 XPEDITION 425 (A00CK42AA) - Swing Arm/Rear Gearcase Mounting
2000 XPEDITION 425 (A00CK42AB) - Swing Arm/Rear Gearcase Mounting - A00ck42aa
2001 325 MAGNUM 2X4 HDS (A01CB32FC) - Swing Arm/Rear Gearcase Mounting - A01cb32aa
2001 325 MAGNUM 4X4 HDS (A01CD32FB) - Swing Arm/Rear Gearcase Mounting - A01cd32aa
2001 500 MAGNUM 500 HDS (A01CD50FB) - Swing Arm/Rear Gearcase Mounting - A01cd50aa
2001 MAGNUM 325 2X4 (A01CB32AA) - Swing Arm/Rear Gearcase Mounting
2001 MAGNUM 325 2X4 (A01CB32AB) - Swing Arm/Rear Gearcase Mounting - A01cb32aa
2001 MAGNUM 325 4X4 (A01CD32AA) - Swing Arm/Rear Gearcase Mounting
2001 MAGNUM 325 4X4 MOSE (A01CD32AB) - Swing Arm/Rear Gearcase Mounting - A01cd32aa
2001 MAGNUM 500 (A01CD50AA) - Swing Arm/Rear Gearcase Mounting
2001 XPEDITION 325 (A01CK32AA) - Swing Arm/Rear Gearcase Mounting
2001 XPEDITION 425 (A01CK42AA) - Swing Arm/Rear Gearcase Mounting
2001 XPEDITION 425 (A01CK42AB) - Swing Arm/Rear Gearcase Mounting - A01ck42aa
2001 XPEDITION 425 (A01CK42CA) - Swing Arm/Rear Gearcase Mounting - A01ck42aa
#7 ·
This Polaris 1520183-117 RIM-REAR, 8.5/10,SILVER is used in the following models and assemblies:
1993 250 2X4 (W937527) - Rear Wheel Drive Assembly
1993 250 6X6 (W938727) - Middle Wheel Assembly 6X6 250
1993 250 6X6 (W938727) - Rear Wheel Drive Assembly 6X6 250
1993 350L 2X4 (W937539) - Rear Wheel Drive Assembly 2X4 350L
1993 350L 4X4 (W938139) - Rear Wheel Drive Assembly 4X4 350L
1993 350L 6X6 (W938739) - Middle Wheel Assembly 6X6 350L
1993 350L 6X6 (W938739) - Rear Wheel Drive Assembly 6X6 350L
1993 EURO 350L 4X4 (S938139) - Rear Wheel Drive Assembly 4X4 350L
1993 EURO 350L 4X4 (S938139) - Rear Wheel Drive Assembly 4X4 350L W938139
1993 EURO 350L 6X6 (S938739) - Middle Wheel Assembly 6X6 350L
1993 EURO 350L 6X6 (S938739) - Middle Wheel Assembly 6X6 350L W938739
1993 EURO 350L 6X6 (S938739) - Rear Wheel Drive Assembly 6X6 350L
1993 EURO 350L 6X6 (S938739) - Rear Wheel Drive Assembly 6X6 350L W938739
1994 300 2X4 (W947530) - Rear Wheel Drive Assembly 2X4 300
1994 300 4X4 (W948130) - Rear Wheel Drive Assembly 4X4 300
1994 300 6X6 (W948730) - Middle Wheel Assembly 6X6 300
1994 300 6X6 (W948730) - Rear Wheel Drive Assembly 6X6 300
1994 400L 2X4 (W947540) - Rear Wheel Drive Assembly 2X4 400L
1994 400L 4X4 (W948140) - Rear Wheel Drive Assembly 4X4 400L
1994 400L 6X6 (W948740) - Middle Wheel Assembly 6X6 400L
1994 400L 6X6 (W948740) - Rear Wheel Drive Assembly 6X6 400L
1994 NORWEGIAN 400L 4X4 (N948140) - Rear Wheel Drive Assembly Swedish 4X4 400L S948140
1994 NORWEGIAN 400L 6X6 (N948740) - Middle Wheel Assembly 6X6 400L, Swedish S948740 & Norwegian
1994 NORWEGIAN 400L 6X6 (N948740) - Rear Wheel Drive Assembly 6X6 400L, Swedish S948740 & Norwegian
1994 SWEDISH 400L 4X4 (S948140) - Rear Wheel Drive Assembly Swedish 4X4 400L
1994 SWEDISH 400L 6X6 (S948740) - Middle Wheel Assembly 6X6 400L, Swedish & Norwegian N948740
1994 SWEDISH 400L 6X6 (S948740) - Rear Wheel Drive Assembly 6X6 400L, Swedish & Norwegian N948740
1995 300 2X4 (W957530) - Rear Wheel Drive 2X4 300
1995 300 4X4 (W958130) - Rear Wheel Drive Assembly 4X4 300
1995 400L 2X4 (W957540) - Rear Wheel Drive Assembly 2X4 400L
1995 BIG BOSS 6X6 400L (W958740) - Middle Wheel Assembly 6X6 400L - U.S. , Swedish S958740 & Norweg
1995 BIG BOSS 6X6 400L (W958740) - Rear Wheel Drive Assembly 6X6 400L - U.S. , Swedish S958740 & No
1995 MAGNUM 2X4 (W957544) - Rear Wheel Drive Assembly (After Serial #2295881) Magnum 2X4
1995 MAGNUM 2X4 (W957544) - Rear Wheel Drive Assembly (Prior To Serial #2295881) Magnum 2X4
1995 MAGNUM 4X4 (W958144) - Rear Wheel Drive Assembly
1995 MAGNUM 4X4 (W958144) - Rear Wheel Drive Assembly (After Serial #2501800)
1995 NORWEGIAN MAGNUM 4X4 (N958144) - Rear Wheel Drive Assembly - W958144
1995 NORWEGIAN MAGNUM 4X4 (N958144) - Rear Wheel Drive Assembly (After Serial #2501800) - W958144
1995 SWEDISH MAGNUM 4X4 (S958144) - Rear Wheel Drive Assembly - W958144
1995 SWEDISH MAGNUM 4X4 (S958144) - Rear Wheel Drive Assembly (After Serial #2501800) - W958144
1995 XPLORER (W959140) - Rear Wheel Drive Assembly Xplorer 4X4
1996 400L 6X6 (W968740) - Middle Wheel 6X6 400L & 6X6 400L Norwegian - N968740
1996 400L 6X6 (W968740) - Rear Wheel Drive 6X6 400L & 6X6 400L Norwegian - N968740
1996 MAGNUM 2X4 (W967544) - Rear Wheel Drive Magnum 2X4
1996 MAGNUM 4X4 (W968144) - Rear Wheel Drive Magnum 4X4 & Swedish Magnum 4X4 S968144
1996 MAGNUM 6X6 (W968744) - Middle Wheel Magnum 6X6 & Magnum 6X6 Swedish - S968744
1996 MAGNUM 6X6 (W968744) - Rear Wheel Drive Magnum 6X6 & Magnum 6X6 Swedish - S968744
1996 NORWEGIAN 400L 6X6 (N968740) - Middle Wheel 6X6 400L - W968740 & 6X6 400L Norwegian
1996 NORWEGIAN 400L 6X6 (N968740) - Rear Wheel Drive 6X6 400L - W968740 & 6X6 400L Norwegian
1996 SPORT 400L (W968540) - Rear Wheel Drive
1996 SWEDISH MAGNUM 4X4 (S968144) - Rear Wheel Drive Magnum 4X4 W968144 & Swedish Magnum 4X4
1996 SWEDISH MAGNUM 6X6 (S968744) - Middle Wheel Magnum 6X6 - W968744 & Magnum 6X6 Swedish
1996 SWEDISH MAGNUM 6X6 (S968744) - Rear Wheel Drive Magnum 6X6 - W968744 & Magnum 6X6 Swedish
1996 TRAIL BLAZER ES (W967827) - Rear Wheel Drive - W968540
1996 XPLORER 300 (W969130) - Rear Wheel Drive Assembly Xplorer 300
1996 XPLORER 400L (W969140) - Rear Wheel Drive Xplorer 400L
1996 XPRESS 300 (W969530) - Rear Wheel Drive Xpress 300 & Xpress 400 W969540
1996 XPRESS 400 (W969540) - Rear Wheel Drive Xpress 300 W969530 & Xpress 400
1997 BIG BOSS 6X6 400L (N97AE38D) - Middle Wheel Big Boss 6X6 400L W97ae38a
1997 BIG BOSS 6X6 400L (N97AE38D) - Rear Wheel Drive Big Boss 6X6 400L W97ae38a
1997 BIG BOSS 6X6 400L (W97AE38A) - Middle Wheel Big Boss 6X6 400L
1997 BIG BOSS 6X6 400L (W97AE38A) - Rear Wheel Drive Big Boss 6X6 400L
1997 MAGNUM 2X4 (W97AA42A) - Rear Wheel Drive Magnum 2X4
1997 MAGNUM 4X4 (W97AC42A) - Rear Wheel Drive Magnum 4X4 , Swedish Magnum 4X4 S97ac42e & Norwe
1997 MAGNUM 6X6 (W97AE42A) - Middle Wheel Magnum 6X6 & Swedish Magnum 6X6 S97ae42e
1997 MAGNUM 6X6 (W97AE42A) - Rear Wheel Drive Magnum 6X6 & Swedish Magnum 6X6 S97ae42e
1997 NORWEGIAN MAGNUM 4X4 (N97AC42D) - Rear Wheel Drive Magnum 4X4 W97ac42a, Swedish Magnum 4X4 S97ac42e & Norwe
1997 SWEDISH MAGNUM 4X4 (S97AC42E) - Rear Wheel Drive Magnum 4X4 W97ac42a, Swedish Magnum 4X4 & Norwe
1997 SWEDISH MAGNUM 6X6 (S97AE42E) - Middle Wheel Magnum 6X6 W97ae42a & Swedish Magnum 6X6
1997 SWEDISH MAGNUM 6X6 (S97AE42E) - Rear Wheel Drive Magnum 6X6 W97ae42a & Swedish Magnum 6X6
1997 XPLORER 300 (W97CC28C) - Rear Wheel Drive Xplorer 300
1997 XPLORER 400L (W97CC38C) - Rear Wheel Drive Xplorer 400L
1997 XPRESS 300 (W97CA28C) - Rear Wheel Drive Xpress 300 & Xpress 400L W97ca38c
1997 XPRESS 400 (W97CA38C) - Rear Wheel Drive Xpress 300 W97ca28c & Xpress 400L
1998 BIG BOSS 500 6X6 (W98AE50A) - Middle Wheel - S98ae50e
1998 BIG BOSS 500 6X6 (W98AE50A) - Rear Wheel Drive - S98ae50e
1998 MAGNUM 2X4 (W98AA42A) - Rear Wheel Drive
1998 MAGNUM 4X4 (W98AC42A) - Rear Wheel Drive
1998 NORWEGIAN BIG BOSS 500 6X6 (N98AE50D) - Middle Wheel - S98ae50e
1998 NORWEGIAN BIG BOSS 500 6X6 (N98AE50D) - Rear Wheel Drive - S98ae50e
1998 NORWEGIAN MAGNUM 4X4 (N98AC42D) - Rear Wheel Drive - W98ac42a
1998 SWEDISH BIG BOSS 500 6X6 (S98AE50E) - Middle Wheel
1998 SWEDISH BIG BOSS 500 6X6 (S98AE50E) - Rear Wheel Drive
1998 SWEDISH MAGNUM 4X4 (S98AC42E) - Rear Wheel Drive - W98ac42a
1998 XPLORER 300 (W98CC28C) - Rear Wheel Drive Xplorer 300
1998 XPLORER 400L (W98CC38C) - Rear Wheel Drive Xplorer 400L
1998 XPRESS 300 (W98CA28C) - Rear Wheel Drive Xpress 300
1999 BIG BOSS 500 6X6 (A99AE50AA) - Middle Wheel - A99ae50da
1999 BIG BOSS 500 6X6 (A99AE50AA) - Rear Wheel Drive - A99ae50da
1999 INTL BIG BOSS 500 6X6 (A99AE50DA) - Middle Wheel
1999 INTL BIG BOSS 500 6X6 (A99AE50DA) - Rear Wheel Drive
1999 XPLORER 300 (A99CC28CA) - Rear Wheel Drive
1999 XPLORER 400 (A99CG38CA) - Rear Wheel
1999 XPRESS 300 (A99CA28CA) - Rear Wheel Drive
2000 SCRAMBLER 2X4 (A00BA38CA) - Rear Wheel
2000 XPLORER (A00AG25CA) - Rear Wheel
2000 XPLORER 400 (A00CG38CA) - Rear Wheel
2001 SCRAMBLER 500 2X4 (A01BA50AA) - Rear Wheel
2001 SCRAMBLER 500 2X4 (A01BA50AB) - Rear Wheel - A01ba50aa
2001 SCRAMBLER 500 4X4 (A01BG50AA) - Rear Wheel
2001 SCRAMBLER 500 4X4 (A01BG50AB) - Rear Wheel - A01bg50aa
2001 XPLORER (A01AG25CA) - Rear Wheel
2001 XPLORER 400 (A01CG38CA) - Rear Wheel
2002 MAGNUM 500 (A02CD50AA) - Rear Wheel - A02ba50aa/Ab
2002 SCRAMBLER 500 2X4 (A02BA50AA) - Rear Wheel /Ab
2002 SCRAMBLER 500 2X4 (A02BA50AB) - Rear Wheel - A02ba50aa/Ab
2002 SCRAMBLER 500 4X4 (A02BG50AA) - Rear Wheel /Ac
2002 SCRAMBLER 500 4X4 FREEDOM (A02BG50AC) - Rear Wheel - A02bg50aa/Ac
2002 XPLORER 400 (A02CG38CA) - Rear Wheel
2003 SCRAMBLER 500 4X4 (A03BG50AA) - Rear Wheel
2004 A04BG50AA SCRAMBLER 500 4X4 (A04BG50AA/FA) - Rear Wheel
