Painting the motor
1 reading
3.1K views 8 replies 7 participants last post by  ThorsHammer
Hoping I am posting in correct area. So I painted my motor with two light coats of black hi temp engine paint. A friend of mine has advised me to strip the paint off. His reasoning is that black will increase the engine temp where i may have cooling issues since it's a 2 stroke motor. I was advised to go with keeping it a silver color or blue, anything but black. Anyone have painted their motors black and had issues? Or should I take his advice and strip off the black paint?
#2 ·
Is the engine free air cooled (no fan moving air across the engine) If it isn't water cooled, I would strip off the paint regardless of color. Seems to me that anything on the surface of the engine would inhibit heat transfer to the air. If its a water cooled model, i would think it might run a bit warmer but it shouldn't make a difference.
#4 ·
In that case, it might run a bit warmer than before, but it shouldn't be a problem.
#8 ·
The paint won't hurt cooling much, if even at all..... now if you chromed it, that would be a completely different story. Chrome works as insulator.
Note, many motor cycles (even air/oil cooled Harley's) have "blacked out" engine options these days!!
#9 ·
you might be slightly warmer, but there isn't enough of an insulation factor in paint to make much of a difference.
