2013 sportsman 400 suspension help
1.6K views 5 replies 5 participants last post by  davidwhop
I have a 2013 sportsman 400 and need to beef up the suspension. Would like to install stiffer suspension springs but can't find any. High lifter and epi were no help. Has anyone else tried to beef up your 2013 400 ?
#2 ·
As far as I know, they've used the same suspension springs for a gazillion years now...not really sure why they couldn't help you? Because the newer 400s are essentially a 500 with a smaller engine, springs for the 500 should work.
#5 ·
A lot of aftermarket companies have not got there stuff together when it comes to the newer models. If you have a (2011 +)400 always tell them that you have a 500 and the stuff will fit and work like a charm. Only time you need to tell them you have a 400 is when you are buying motor stuff, carb kit, jet kit, etc. These bikes even share the same exhaust system. Every thing is the same except for the engine block and carb.
