vin polaris magum 425
6K views 8 replies 4 participants last post by  tt425
where is the vin located is it stamped on the frame or on a tag. the one I have is a 95 425 4x4 model w958144
#2 ·
The vin number I believe is stamped on the left side of the frame between the oil tank and the pvt cover. You are right it's a 1995 Model. I will look on mine 2moro and find out.
#5 ·
I found a tag that has the model number in big numbers then a small number that is 7074674 could this number be the vin
On a 1995 model the vin number is located on a frame rail near the gear shifter or on the frame rail above the rh front tire, also its under the seat on the uppershock mount cross member.
#6 ·
I don't think Polaris used the 17 digit VIN until 1997 and after.
#9 ·
The vin # is on a plate on the frame rail just foward of the gearshifter. I just went and looked at mine. My VIN started with *232- - - - totaling 7 digits not including the * symbol.
