2000 Polaris magnum 325 floods and barely runs
14K views 4 replies 4 participants last post by  skidoolingo
Ok so I have a 2000 polaris magnum 325 and all it does is bogs, It wont move, doesn't idle, and shoot a whole bunch of exhaust. So we took the airbox top off and there was almost a inch of gas inside So then took the carb off there was a little piece of metal that holds the float in place inside so I put that back in place, tested it nothings leaking when I blowed into the hose. Cleaned it put everything back together and still runs the same it wont move! we have tried tapping it with a screwdriver but it still doesn't work. Can someone tell me what wrong with it???
#4 ·
X3 I had the same thing happen, drained a whole tank over the course of a week, luckily it all evaporated by the time i wanted to use it. If your machine has the valve on the side that shows "on/off/res" you can turn it to off to stop the leak while it sits
