Outlaw 110cc no spark
13K views 8 replies 6 participants last post by  SennasLoafers
Hello all,
I have read through all the threads I could find in relation to my issue, and have not found anything. Currently I have a 2016 Outlaw 110, with no spark. battery is great, it turns over, just is not generating a spark. the plug looks good, but i'd like some pointers on the best way to test the Stator, ECU & Ignition coil. Or any other part of the system that could cause this issue..if I could rule out any of the 3 components that would be great. I'm about to just throw an ignition coil at is since its the most affordable option..
Thank you!
#2 ·
Check for 12v on the red/yel wire of the coil - no voltage, replace the 5 amp fuse - check for DC volts on the red/wht wire on pin 26 of the ECU - test the stator (pulse generator) by checking continuity between the blue/yellow and green wires - if it has continuity and is not shorted to ground, check the peak voltage output (typically 3 to 5 volts) - if you haven't found the problem up to this point and all tests good, flip a coin and either find the bad connection in the wiring (including grounds), replace the ECU or take it to the dealer and have them run the diagnostics on it.
#3 ·
thank you! I know I have voltage at the coil, so we can rule out the fuse. I will check pin 26 on the ECU, what would this indicate? and on the stator, where would I be checking the peak voltage? I assume directly at the ignition coil would be the best place? thanks, I apologize, I am an electrician, but this fourwheeler stuff is a bit different than what I am used to working on. Its hard to wrap my mind around this without a schematic. I should probably just break down and buy the service manual for it.
#9 ·
So here's an interesting one.... check the EFI Relay (on R-side, visible between front fascia / R-side cover mounted on frame that says "EFI" with big bold white letters) and perform a resistance / continuity test on that.
These Outlaws run their spark thru the EFI Relay ironically enough. Found that out the other day diagnosing a fuel pump and testing other items to verify all was well.
